Bawb, is it possible...
Connor
Connor
To have one of your Genies with a motor installed like a slide in instead of a PTO?
look here Chris....
they put a man on the moon
soooooo i suppose it's possible
to power a direct drive
wit a LAWN MOWER ENGINE......
however that would make that person a candidate
for the worlds most stupid person......
Connor
Connor
Bawb, they use those engines for generators and all sorts of things, they're just engines.
What about a genie on a cart, kinda like that Amtex Prowler thingy, can you do that?
Oh, and money talks, bullshit....... stays in Michigan. !gotcha!
OK i'll speak s l o w e r so's you can unnerstan.......
one of the BEST advantage of a direct drive is the FREE HEAT.....
off the vans motor..........properly plumbed a van motor hottest spot is after the water has run through the engine and JUST BEFORE it enters the radiator it can be as high as 220 or 230........
this is FREE...and
SAFE heat...............
aircooled lawnmower engines CANNOT produce that kinna heat..........wit their exhaust alone!
so hey Marty, blow me
Connor
Connor
I didn't ask you the principals, I asked you if you could build it, you air condtioner-less, fender-riveting hack.
You're the guy that said glides were stupit and that you needed the metal contact on the carpet to "scrub" the carpet clean. Then yous used one and changed your mind.
Sometimes I wonder why I talk to you. Send me my flowers back!!!
the A/C bracket!!!
a better rivit job you'll never find
i made that truck last over 23 years looking good.....
NOW you wan yor flurres back.........
Connor
Connor
I saw that you discovered AC for the SG on another thread, I remember when you used to say "who needs AC" and that it "can't be done, but you don't need it anyway"
So, can you build it, you wishy washy, white pantsed freak?
rhino1
Chris Bolin
The SG I had was equipped with a/c. Didn't know it was a big deal.
