Boxer 421 dumping water
jerry ACC
Jerry Lightcap
My Boxer has been cycling water into the waste tank for years. There are times I can only clean two rooms with a full 75 gallon fresh water tank ( only one sofa). I have changed all of the sensors several times, changed and cleaned the solenoid a number of times with little to no improvement.
Question,
Could I convert the solenoid to dump back into my FRESH water tank instead of the waste tank ?
It is hot water but I think when it mixes with the cold freah water it should be cool enough not to hurt the pump ?
Question,
off the top of my head I cant think of a reason why not.....have you replaced the therm valve.....some of these you have to be careful with...not knowing the type you have but on some you have to be careful how deep you screw in the hose barb fitting......if you go to deep it will hit the spring.....
I experienced this with my CDS....like to never figured it out and all it would do is dump into the waste tank.........
Charlie Lyman
Charlie Lyman
Have you replaced the thermal valve that is on the pressure regulator?
gtech12v
Yes you can route the water to the fresh tank most pumps have a 145* temperature relief valve to protect from over heating
Boxers have a very cheap type of valve you can use a different one
