Dodge van radiator replacement
N GA
BradFenstermaker
Anyone done this at home?
Heard most of the front clip has to come off.
I am pretty mechanical but want to finish in a day.
My copper on the low end for the tranny cooler is toast.
Doug Cox
Delavan, WI
Doug Cox
All you have to do is remove the shroud. It comes out of the top. It's held in by 4 bolts. You also have to disconnect the trans lines at the bottom of the radiator. It should take only a couple hours.
Damn Brad..If anyone could figure this out and knock it out in a day...... you could....
N GA
BradFenstermaker
YEAH YEAH YEAH
My neighbor mechanic made me panic after tellin me the front clip has to come off.
Chatted with Doug and I will look at it more tommorrow.
May try the swap this week or the next weekend.
N GA
BradFenstermaker
Hey Piggly Wiggly I wouldn't talk about equipment needing repair.
Atleast my Dodge and UD will start if I forget to put the charger on.
