- Joined
- Oct 6, 2006
- Messages
- 116,978
I have been using number beta4 for 8 days now and two problems arose.
One is a mystery hole right next to the budge that the anchor/insert nut that the top left frame screw goes into. It took 7 days of stress to cause it to leak.
If you ordered one from Olsen once you get it you'll know what I'm talking about. Mytee is aware of the problem and has fixed it in the roto molding.
I suggested they send out a small tube of Nick O' Goo to the 9 owners for an easy fix rather then doing a recall.
Second "problem"...
With all the changes they have made in the tank itself it is no longer a five gallon capacity sprayer.
I thought I was going nuts using so much pre spray, 5 gallons in 300 to 400 feet, so I bucket tested it today. It's more like 3.5.
John said before the changes it was 4.7 gallons.
Still better then a Multi but a HF die hard will have a hard time switching over.
Second "problem"...
