Bob Foster said:
Judson Jones was in church one day and saw a heater being used in a baptism. After the service he went up and looked at it. He got to thinking that was a fine simple heater and he figured he might be able to use something like it it with his Judson TNT truckmount.
That is how Little Giant got into the carpet cleaning supply. Through out the years Jud, Dick and Les are responsible for why the thing is now so well suited and trouble free for our industry.
If anyone knows the answer it would be Judson, Les or Dick.
The heaters that we were using before Little Giant were Ewings. They were steel coil heaters primarily used with pressure washers. When we first got a Little Giant Heater, I think it was somewhere around 1973 it seemed to work just fine with a truck mount.
If you remember the first Little Giant Heaters had the thermostats on the bottom. The ony problem with this design is if the thermostat was out of adjustment, and you released the trigger, the heater was capable of spiking. In other words the temperature climbed too high before the thermostat shut the flame off.
Knowing that heat rises, we took a number 3 Little Giant heater and mounted the thermostat at the top. This eliminated the spiking and would shut the flame off immediately. We were also part of the development of the #4 Little Giant HT. When they were first put on the market they had an electronic thermostat and ignition system.
We took one of the heaters and mounted a #3 HT system on it and it worked just fine. If anyone has any other questions about the Little Giant heaters I will be glad to answer them. I think we probably sell more of them than anyone else.
