Strange spinner tool for $150
I hated mine. You can't get under toe kicks and if you want to lift it to get to the edges, it makes a mess.
On the other hand, that's super cheap. So if you have a tile wand, you can use that to get to the areas it won't go. Because the price listed is a good deal for it's value. I got ripped off when I bought mine from dixie steamway ($500) back in '05
Acp
Seattle
Bjorn Marshall
its horrible, I wouldnt bother. I damaged a slate floor because of it a few years ago.
The vacuum pulls the housing and the jets will smack into the floor. The vacuum relief slot pulls your shirt in and soaks it because its right on the handle your moving past your body as you clean.
Also the jet bar hits the housing inside and gets stuck, then you have to bend it out of the way so it will spin.
Its a sh!tty tool
CtcClean
Palm Coast, FL
paul g
Yes. I have that exact same tool. It doesn't get into the corners or under tight spots and I use a grout brush with it.
