The best way to apply Floor Finish to a wall?
I have a SaLteEo job coming up that will need the wainscoting "waxed" as well.
What sort of applicator works best and how do I avoid drip lines?
Fon Johnson
Wow, you mean really putting regular floor finish on it? Never thought I'd see the day you'd be doing that..
You will need to put it on really thin, and I would use a sponge. It will probably take many very thin coats. Just a hair to heavy and it will run. The solids will make it a challenge.
boazcan
Bryan C
I have applied an enhancer to a travertine fountain from the bottom up to avoid the streaks. If it does run, it will be on top of a coated area and should be easy to wipe without leaving marks. Did it with a big grout sponge.
Ron lippold
Mikey remember that new fangled 1/2 gallon pump up that you recently discovered. Spray on the wall wipe with a micro fiber towel and rinse the sprayer out between coats
Tony Neville
Tony Neville
Would waxing the wall be easier or look better then lightly sanding and using wipe on polyurethane? I would not have thought to try and use wax.
Tony
Walt
It will look terrible in a few years and be near impossible to strip.
Why do you think it will look bad?
Not like anyone will be walking on it.
Ron lippold
mikey spray it on wipe it off 4-5 coats and you be fine i do alot of windo sills this way
do u floor guys still use the term wax?
like a rug sucker and the word soap.
in a few years Mikey will be retired in the D.R., who cares about stripping it.
try not to....but when you tell people "we are gonna finish the floor" they look at you funny...
trying to spread the word....floor finish
Larry B
Larry Burrell
Thats no shit
Tell them you can re-finish the floor on such & such date they will ask when you will wax it
