tile problem.....
normally I use the shut off valves with the plastic shut offs........but I had one break on me and the only one I had on the truck had a metal shut off......
long story short...it got drug across a tile floor and the metal shut of left lines/scratch marks on the surface of the tile...is there anything that will buff these out..........
BLewis
Billy Lewis
Jim I accidently scratched a tile floor while moving a refrigerator once, didn't have anything with me but the inside of a red
Pad, scrubbed it with that and buffed with brush on 175 and all came out good
BradFenstermaker
not sure Jim but a scotch brite pad may do the trick, anything aggressive should buff it off hopefully.
I try to always leave the sol line hooked to turbo until I am over a moving blanket or out of the house.
Let us know how you come out.
Glass and metal magic
Groundfloor.org
Don't leave home without it
Johnny
Johnny
Abrasive household cleanser, like Comet, will remove metal scratches from ceramic tile.
boazcan
Bryan C
Done it a couple of times -
straight acid cleaner of your choice and 000 steel wool
alazo1
Albert Lazo
I only know how to take these marks off on a porcelain sink. Comet and a cork. It would be a pita to do this on a floor though.
adamh
Adam Hale
Did it with a wand once. Comet and scotch brite worked great.
GeneMiller
gene miller
over aggressive abrasives can damage a finish especially if it is glossy.
gene
