Tile wand
The same head is available in a hand tool (w/ten foot hide A hose) from PMF.
We love it for steps, counters, walls, showers, around toilets etc.
I can't see having the hand tool AND that wand option both. We prefer a hard floor wand with a 14" head for corners and under things the Spinner wont get to
GeneMiller
gene miller
If you'd apply the right products you wouldn't need to do all that work.
Gene
dealtimeman
Everyday is Saturday.
Michael
I thought the product mikey was using was pretty good.
What would you recommend gene?
and I'm still trying to find an acid (with a pH of 13:eekk:) that will cling to walls and eat that spooge off.
Reactions: hogjowl
realclean
Jesse Lowe
Oh and I do not want to bend over in order to get into the tight spots unless I have to.
GeneMiller
gene miller
Looks like mostly soap scum with some mold and minerals in it. Easy off oven cleaner will remove it no problem. Rarely use an acid to clean tile. I also use a product similar to clr but the name is eluding me right now. I have some zep on board but rarely use it because it's so strong.
Gene
