Wax Extraction With A Portable
Swani
Any reason I can't do wax removal with my portable and Mikey's Hard Surface wand? Other than wax in the waste tank, what's to worry?
Should work fine except for the wax build up in the tank and hoses. I have an old portable that I use for that. I clean out the tank and hoses with stripper. I don't know if I would want to do it with a nice machine.
Reactions: Living The Dream
You can do it, but I’m not sure why you want to unless you’re broke. A 12 gallon Rigid wet vac will do the same thing and is built for that type of work. With the foam wet filter, you’re golden. $129-150.
Swani
I'm always broke, and I actually already have a couple of those shop vacs and they are a pain in the ass to dump, when you run them till they are full water poors out the hose when you unhook it and then it spills out the vac port. The hose get twisted and when you try to untwist it the machine sometimes tips over.
With my portable I can run 25 - 50' of hose, it's easy to drain, and I can use a decent wand.
Reactions: Kenny Hayes
Jeff T
It comes as no surprise, wax can be dealt with in 2 ways.
Either with chemicals, or heat…
Both are effective, both are a PITA to clean out of a portable.
I prefer the speed of chemistry with a portable, but prefer heat when using a TM.
That’s crazy. They have a drain plug at the bottom of the machine that you just have to unscrew. They hold the same amount as a porty or more if you get the 16 gallon ones. Use defoamer, again you’re golden. You can hear it when it gets full just like a porty. I always use that with Kiavac 28” vacuum tool with a fifty foot 1 1/2 hose adapted.
Do you pick up slurry with your tm? But yes, and that’s why I use wet vacs unless I’m using an auto scrubber.
This with a Rigid wet vac is the cats ass for stripping small floors. I wouldn’t even want to get a good Mikey floor tool in that. It will swivel to even get behind toilets beloit or not.
It’s gone up a hundred since the last I bought, but it’s so worth it.
I also use that old portable for rinsing the slurry. I use a neutral floor cleaner for that.
Hoody
Steven Hoodlebrink
Double post?
As above. Your portable is too valuable, and your time too valuable, for the consequences of getting that mess into your unit.
Truck mounts?
We’ve had to do some expensive repair work for cleaners who have made that mistake.
I’m glad no one recommended that
Double post?
Test
Truck mounts?
Apparently Courtney has had great success using a PEX 500 for finish/ wax removal. Daily, not occasionally.
Hydra Master created a in tank filtration system for him that will be available to all soon
check it out in Indy
  • Wow
I had an EDIC porty and it wasn’t worth 2 cents as a porty. 110 psi 😏I started using it as a vacuum for slurry and might’ve lasted 6 months. You couldn’t clean it enough. That crap gets in the vacuum motors and soon it just craps out😏
Test
What the h e double ll? I helped convince Courtney go to the PEX and now he’s using it for
slurry recovery😳 Buy em books, send em to school, and all they want to do is chase the teacher around the desk!
Reactions: Condog
Ok, you've convinced me to go with the shop vac.
Get the rubbermaid blue wax bucket and the 18” rayon flat mop on a dust mop ring and handle, and now you can really fly. All that is a little pricey to start, but if you want to do a lot, it’s the only way to go. Now you know why I pull a trailer🤣
Most of the floor guys use a Tennent or Nobles or something with the squeegee on the front and push it around. When Diana was on the #truck with me, I wanted to buy one for her.😂 She nixed that real fast. She said, I don’t want to push a tank full of water around. She just used the Kiavac Squeege wand and 50’ of hose. Actually it was effortless. (says me😏)
