Blower question
my blower is hard piped (for the lack of a better way of putting it) to the waste tank........
I have been getting a few air leaks here and no matter what I do I can't get rid of them......I think the rubber reducers are shot........
I found this picture in one of my folders....
I have a bearing/belt/and hose place I work with for most the things on my truck here in town and I can get that flex hose pretty cheap...........
my question is.....where the flexible hose is clamped to the blower it looks like a pipe nipple. is there a reason why it is not a plastic fitting.......
would the plastic hold up against the heat and the vibration of the blower......I am not to crazy about the metal nipple on there...I would be afraid that in time it would start to break down and flake into the blower........
Your rig doesn't look as clean and well kept as Mellon Hed's rig does.
Are you a hack? :wink:
guess it is all in who you talk to................
Shane T
Shane Tiegs
Jim doesn't your application have a metal nipple threaded into the blower. I believe the inside diameter of the pvc will be less than the metal would be. I've never had as big a blower as yours but have used both metal & pvc on the inlet side of the blower without any problems.
I really have no idea what is under there.................
never took it off.........I bet it is metal........
just put a little tape under where the rubber meets the metal, that will take out the air leaks
I use black 4" ABS pipe fittings, biggest challenge is they crack at the blower, they still don't leak that much. Easy enough to replace.
WTF they use the word "reduced" when it comes to an AT/V???
what is this world coming to
one of the problems is that it don't line up.........
there is a slight angle upward going to the waste tank
so the pipe does not sit straight in the rubber boot coming off the blower.....
the rubber boots are not soft and flexible they have hardened up
so because of the already bad angle and the hardened rubber it just don't want to seal anymore.......
Jim, you'd never get that KanaFlex to make that tight turn, I'm with Ron, pick up some new rubber and call it good.
Shane T
Shane Tiegs
Jim, You probably don't need to push that elbow down all the way in the boot. Fudge it a little on both if necessary. It should line up then.
Shane
Jim;
You can get a silicone rubber reducer to replace that deteriorating one.
They resist heat better and should last many years of operation.
Chads
Mikey gave you the best solution get a stainless steel nipple or aluminum one and hard pipe it all the way
Larry Cobb said:
Jim;
Do you carry something like that Larry ???
nickreal
I would use ABS Fitting instead of PVC. ABS is meant for drainage and it has better sweeping turns. Should have better flow than that water type fitting you have on there. You can also get whats called a "Street 90" it has a hub fitting on one side where you can glue the tubing into and the other side of the fitting is the same size as the tubing so it will slip into your rubber "no hub coupling". You can also trim a little of the tubing size part of the fitting to line things up.
