- Joined
- Oct 6, 2006
- Messages
- 116,982
Your typical HWE guy does most if not all of his agitating with a Glideless wand.
That is a fact.
These days a percentage of them have switched to using glides to help with their lower backs and shoulders and possibly to get better dry times.
So I assume since they've lost their main source of agitation (the wand's lips) that they now either use a Grandi Groomer, use more stronger pre spray or maybe just maybe use a mechanical agitator.
Now there are also many cleaners who bought a Glide to try out but soon tossed in his bucket along side the wand wheels, pulsating forward and backward spraying jets and probably a Lip or three, never to be used again....
I have talked to more then one of these guys who gave up because "they don't clean good"....
Now all of us Online nerds know that for glides to really work well, you need to help them out a bit with prep work...Your average BDCC that learns every thing they know from their not so up to date local supplier will most likely never figure it out
Would higher flow also help this type of cleaner out ?
Can tons of water help compensate for lack of agitation? Or would it just cause over wetting.
It's my opinion that mega flow wands should only be used after a good prepping to loosen the soil (pre vac, quality pre spray, mechanical agitation and dwell time) in a one or two backwards rinse passes only.
Now we all know that very few cleaners can charge enough to clean in this fashion on a daily basis, right?
I was never a Steam Way Flood jet guy so I dont know if that set up ever really worked out....High flow/heat but weak vacuum.
Considering that the only guy I know, Loren Egland, prefers his RV for heavy soil, I'm guess it didn't.
So my question is:
Would it be a wise move for a TM manufacture to only offer a high flow set up?
That is a fact.
So my question is:
