- Joined
- Sep 15, 2007
- Messages
- 44,657
- Name
- bob vawter
Listin' up here Josh...if YOU'D walked she woulda jus got some OTHER smuck to do it...RIGHT? So do the job put yor air dryer down and give her the bill........
And just to clarify you said: "I can't properly cut a seam", "I can't identify pad", "I don't take precautions not to damage walls", "I can't seam carpet", and "I feel that it cost to much to do the job properly".
Sorry, after thousands of water jobs you will never convince me that top down is an acceptable method for drying a structure. I haven't met an adjuster yet that believes in it either and they are paying the bill.
hee heeadcomp said:Were all materials below 16% MC and within 2% of the DS when you picked up your air mover?
adcomp said:carpet padding I believe it should be considered CAT2 almost immediately. quote]
No offense but what you "believe" is irrelevant. Just because "you" believe something does not make it gospel or the standard. And certainly does not make anyone who sees it differently a hack.
R.Chavez said:Just curious. Why is it that some people always remove the pad? Maybe I'm wrong but it seems to me that if you do a good job extracting, you should be able to dry with the pad in place and the pad will still dry faster than the walls, studs, etc.
We rarely remove pad on a clean water loss, it just dries so easily no reason unless the water is contaminated.
We will try to save those materials that are cost effective to save.
As little effort as it takes to dry the pad, versus remove and replace we almost always dry it.
LeeCory said:Craig already answered in great detail exactly what you needed to do with this job in one of the first posts in this thread. I read what he wrote and it couldn't be written much better. That is all the info you need.
LeeCory said:P.S. I know your favorite threads are those where people are arguing....lol
LeeCory said:P.S.S I hope someone has a contest soon so I can win all the equipment I need for restoration. Where is Rich when you need him.
Josh said:Do you guys get urine jobs or what?
Let's say you get a call to clean some carpet in a residence. You get to the house and you notice a Rot or a Great Dane in the dog run. Wow, big dog!
Mrs. Piff answers the door and brings you into the foyer and she goes, "How much will you charge to clean my rugs?" You go, "Rugs? Don't you mean your carpet?" And she's all, "Yeah, my carpet." You ask her to show you the areas she wants cleaned and any areas that may need special attention. So she leads you down to the end of the hall and points to a problem area. She explains that he big dog just went pee a bunch right there.
What do you do?
"Oh, boy! Let's take up the carpet and replace the pad and cut out the drywall and remove the base board andsetanairmoverforaminimumof3daysandairscrubberandmoldinsuranceand......"
