Doggie doo on silk
Jack May
That Kiwi
Palmerston North, New Zealand
John
Hi guys, got this baby in and wondering if you have any suggestions.
John
sweendogg
Bloomington, IL 61704
David Sweeney
Check colorfast... but if color is all clear, I would talk with customer about texture damage and wash it, makeing sure to groom often.
Jack May
That Kiwi
John
I personally haven't colour fast tested yet, but subject to that being ok, I had wondered about a soak for a few hours and then low pressure wash off to see how much of that crap will go. Then use some tanin spotter for the doggie doo staining.
I use a very soft broom for agitation/grooming on silk... is that best or another better option?
John
sweendogg
David Sweeney
John, your procedure sounds pretty darn close to what I would do. If the texture goes or is gone already I can generally get a good improvement with the four way groom process and a carding brush.
sweendogg
David Sweeney
Is that what I cleaned a few months ago. The homeowner has one just like it in a main walk way and has completely destroyed the texture of the rug. I brought it back about 60 % but she had been washing it herself for the last 10 years.
Jose Smith
Just wash it down, should not be a big deal. Make sure the spray of the hose is with the pile and you will not have a problem with the texture. Colors should be safe, but setting them with vinegar might be a good idea (just in case).
Jose Smith
If colour fast is test ok; babies hair brush after soak to litely agitate; extract then check for browing or spotting probs. Good Luck; My Turkish 3x5 hand made Silk rug cost 8k just to give you an idea; and I baught it during a Port call in Turkey at a Factory tour.
I guess they saw you coming if you paid 8G's for a 3x5 rug.
:shock:
