Lyman
- Joined
- May 19, 2007
- Messages
- 1,765
- Name
- Lyman
So what is new in the formula larry.
Larry Cobb said:Since all the guys on this board ...
like to tip the jug ...,
we added more oxidizer to the formula.
A little better deodorizing, stain removal and grout cleaning ability.
Freight prepaid on two 45# pails ...
for customers who tell us they are MB members.
Nate The Great said:....... Freight prepaid to Hawaii or canada??
Jim Martin said:Larry..........I do not know if this last pail of Powermaxx was the so called new and improved but if it was it is not worth a shit....and if it was not....WTF are you doing to this stuff....??....I have been using Powermaxx for about 3 years now and I am well aware of what it can and cant do....the last 2 pails that I have gotten are getting lighter and lighter in color it use to be a darker yellow .....this crap is NOT working worth a damn.....It is supposed to be a powder...it has been a fooking brick...I have to break it up just to get it into the sprayer.....
Did a home today...big empty...well over 3000 sqft.....a house that I have done 3 other times for these people...the first time I did it ..it was really bad and your powermaxx cleaned it right up....They finally moved out so the joint was empty...they told the Realtor that I was the only one that they wanted to clean it.......off white...nylon....nothing special...slight foot traffic....I opened this new pail and it would NOT clean nothing.....thank god I still had some first step on the truck.... which with no effort at all cleaned it right up.........
If this stuff is being home growen in the back of your shop then you need to figure out WTH is going wrong.....If you are the middle man and getting it shipped in and then passing it on to us ....you need to start making some phone calls because someone is short changing you on something....and if this is the new and so called improved stuff....don't send me something with out telling me that you changed it or giving me the option if I even want it or not....at least if people get a heads up then we can at least expect it not to be constant as the pail before it....and I would really suggest you test this crap out first before you start sending it to people.....it would save people a bunch of headaches on both ends..............
If you have a pail of the good stuff...send it to me and I will send you this crap back....If not let me know and I will start looking for a different pre spray....................
HARPER said:I can assure this....There had to be a HUGH drop in the efficiency of the product...
To get Jim that "HOT". :!:
If the powder is "OLD"..It will cake & discolor... :?:
However if this is the NEW formulation.. :?:
It is possible...That this new formula... :?: will NOT work for Jim anymore... :x
I agree that Jim should be notified of the new changes in this formula...![]()
REMEMBER.....We all have different water across the country.... :idea:
This formula could be USLESS in Jim's arsonal anymore....![]()
Why does there always have to be a NEW formula..... :roll:
NEW COKE...really worked well.....![]()
There's a phone number on the package and it wouldn't take over a day or so of use to know a chemical isn't working right.
Lee Stockwell said:Probably better to have given Larry a private heads-up before the very public bash Jim.
Thanks,
Lee
danielc said:HARPER said:I can assure this....There had to be a HUGH drop in the efficiency of the product...
Funny you mention the coke because I swear coke out west tastes completley different than coke in the south. I guess it's the water.
