I had no idea...
That the V/UD's 6 rims are all the same..
DOH!
I was told the fronts could not be rotated to the back...
Just switched mine all up mine and I'm in need of some of those chrome simulators in a bad way.
Who has the best price?
wheel simulators 1-800-215-8007
the 1400 UD has the 6 hand hole 6 lug and the 1200 UD has the 5 hand hole 5 lug
This was the only place I could get them for mine...tight fit for the 1200 but they work great.....
and yes...all 6 rims are the same size....I get mine flipped around all the time..the 2 outer rims on the back are just reversed.....
Bob Foster
DOH!
You can't because they are reversed on the dish of the rims.
The front rims have the bulge going out and then the lug nuts go on.
The backs ones are the same rims but the buldges point to the axles.
If you were to put the fronts on the back then you would end up with the tires turning the wrong direction which is a bad thing. That's why...
from standing at the back facing the truck
outside left goes to inside right
inside right goes to front left
front left goes to outside right
outside right goes to inside left
and inside left goes to front right
you are not reversing your tires but you are taking the nasty rusted dirty rims that were hidden on the inside duels and exposing them
like I said...mine get flopped all the time...that is why I found the simulators to cover the nasty rims...
Shane
Yep! :mrgreen:
Bob Foster
Your right - my bad.
