if you're going to hack a rug...
at least put some plastic down for christs sakes..
GCCLee
C. Lee
Even this noob knows better than that, sheesh.
That's a funny sheep picture.
I was going to say "love the sheep" but caught myself. :eekk:
I'm no sheep humper! :biggrin:
Ron K
Mike I think you might be wrong, the bleeding looks to uniform, maybe they put the rug down on a wet carpet.
Ken Snow
Ken Snow
You can get color transfer from dry rug to dry carpet
Another value of a pad, but even then sometimes there is dye transfer on side, esp if a very thin rug on thin pad cut 2" inside.
Sent from my DROID RAZR using Tapatalk 2
Dry dye transfer is called crocking. Any area rug is going to shift slightly with foot traffic and if overdyed will rub color into whatever it touches.
I've seen lots of it, especially from side wraps. It usually is far easier to remove than wet transfer dye bleeding... which I've also seen more than a few times.
Reactions: Ken Snow
KevinL
Kevin Leach
You might want to fix the spelling of dye on your site Mikey.
Crocking used to be common in brightly colored (usually red/orange shags) adjacent to light carpets.
"Fugitive dyes" in excess of what would "set" were often not rinsed out by some mills.
