Let here your thoughts/ experiences with different spot cleaning machines
Papa John
Lifetime Supportive Member
John Stewart
I'm thinking of offering emergency spot cleaning for some of our clients.
The service would have to be very efficient since we wont be charging our minimum $156.
maybe only charge $52 and the appointment would have to done within say only 20-30 minutes max. Or maybe I'm going the wrong way and should charge more since its an emergency call??
I would be surprised if we were actually able to show up within the same day of the call.
Does the Edic Bravo have enough suction? the plus is its light weight. the downside is I would have the wrong machine for upsells if time permitted.
What are your thoughts about Mytee spotters or mini- portys?
I was going to buy the Rotovac CFX-- but realized I could do the same set-up with my Mytee Air Hog. the downside is the set-up time and weight. the plus is that I could do Upsells if time permitted.
I just got the EDIC... Ill let you know
I have a Mytee and it's been the most reliable tool I've had from them
Upsells as in carpet?
Supposedly you can run a wand off the EDIC...ten or 15 feet..?
Papa John
John Stewart
I don't think I would upsell carpet cleaning with the EDIC-- unless its a small area.-- but what do I know since I haven't tried the EDIC-- so lmk Mikey.
I would upsell with the Mytee air hog set up though-- but then not as easy to set-up---
I've been comparing the Specs of spotting machines-- looks like the EDIC Bravo has the best set-up for spot cleaning?
The only odd thing is how you pull the top off to fill & dump. If that doesn't bother you its a great little spotter.
Yes for water, no for dumping.
But its not bad just different. I'll buy another if we need it.
Between the Mytee and Sandia spotter, I prefer the Sandia one because you can remove the waste tank, it has a extendable handle and nice roller blade wheels on it..
The Mytee has been a workhorse, that's for sure... the dump cap seems to leak over time as to why I prefer the Sandia.. We stopped taking off the dump cap to the Mytee and just dump through the inlet hose..
Papa John
John Stewart
Mikey please try the EDIC with the SS upholstery tool; and report back please.
I noticed when I tried the SS tool with my U.S. products Ultimate Upholstery machine the suction went way down to the point of being useless.
I think these small spotters cant support 1 1/2 hoses or dual vac port heads and may be stuck with the supplied hoses and tool.-- but waiting your opinions.
Ken692
Kenny
We use a stair tool with this and it works great
I'm sure you could cut a hole and put a small dump valve somewhere on that waste tank.
Cool thanks Mike, that looks like it would do good. :cool:
I have one of those dork Evolution wands I could use it to spot with. Might save a little bending down.
15 of hose and a inch and a half wand would let you do some spotting
Papa John
John Stewart
Mikey--Do u have the 85" waterline or 106"?
Papa John
John Stewart
Sorry..
85" or 106" water lift on the vac motor?
Damn auto correct/Fill!!
J Scott W
Jeffrey Scott Warrington
Watch for several new spotting tools with new features and options. Hopefully available during November. We keep getting ideas and feedback from our testers and are making changes.
