Something completly different
Rob
Role
I thought i would share this post from my elder brother who also owns his own carpet cleaning business. It was posted on another forum but i thought i'd share it anyway.
Since 1996, I've been working in the carpet cleaning industry, during which time I have earned a reputation for providing outstanding service to my customers. However, around 2010, I began to suffer from significant pain in my right arm, which was crucial for my daily tasks.
After seeing a medical professional, I discovered that my rotator cuff was severly damaged and that the socket joint was starting to deteriorate—a troubling diagnosis for someone who relies on their physical abilities, especially in a labor-intensive field like carpet cleaning.
Later that year, I opted for a cortisone injection to help manage the pain; it initially worked well and provided relief. For some time after that, everything appeared normal as I continued working without major problems. Yet in 2014 during a routine appointment with my doctor, I learned that my arm required about surgery and i need to take up to six months of rest to heal properly.
As any experienced carpet cleaner would understand, taking six months off is not only impractical but also financially imposible. With bills accumulating, I had to quickly adjust. Determined to keep my business going, I started utilizing my left arm for both the wand and detail tool—a transition that proved quite tough at first. It's one thing to use your dominant hand consistently; it's another entirely to switch abruptly to your non-dominant side.
This shift came with its own learning curve as I worked hard to adapt to using my left arm. Still fueled by the need to stay afloat in this trade it became second nature over time until 2024, until a similar issue occured to the roto cuff on my left arm.
I repeated the same process and switched back to my right arm oncemore as it had completely healed allowing me to switch back and carry on, mainly because i didn't want to under-go surgery.
The moral of the story is that for any newbies out there who are thinking of staying in the carpet cleaning business for a long period of time, try and used both arms...yes become ambidextrous. It might save your business long term.
Great advice i'd say.
Yes, it was a topic of discussion years back on the predecessor board. Good reminder.
Switch hitter,
Obviously there are lots of factors,
Lift setting, type of wand used daily , posture while wanding.
At 61 almost 62 I have a little lock up of my hands.
But I work 3 days a week.
I use to do 4-5 stops 6 days a week, wash rinse repeat.
One day off and do it again.
Now I work one day and need 6 days off.
Not that becoming ambidextrous isn't a good goal.
But I see guys with wand handles half way down the pipe to the jets and hunched over like Quasimodo.
I think that's not a recipe for success.
Stand up straight buy a holed glide, I hate those.
Or buy the certified Grandpa wand from Mike.
My devastator with a hybrid is easiest than the slot.
But on a faux silk smart strand it will still lockdown hard at 14 inches of lift.
Those are the days I regret my life choices of not becoming a rock star.
If you’re an idiot floor guy slinging a mop both ways, and a wand, you’re doomed! Both shoulders kill you. I’m just glad I hated residential! A zipper helps some, but a cimex and OP more😬
Any wand is work the zipper makes you stand up straight and walk.
Still it work
Kenny:
What did this guy say that made you think he was commercial only?
What made you think I thought that?I doubt very much he is! I would imagine he’s mostly residential like most here.
I wasn’t giving him any advice! He seemed to have it figured out to me. I was simply stating or indicating you stay in this business long term, something’s gonna break down!
Rob
Role
Switch hitter,
Yes you're correct there is a lot of factors but we all use the same dominant side when cleaning.
Rob
Role
The moral of the story is that if you're ambidextrious as a carpet cleaner nothing needs to break down. Your body can recover easily when used on a 50/50 basis.
Doing all commercial before I had all the other tools to make life easy, I pretty much learned to do that out of necessity. My point that flew over hogjowls head, was a lotta times we would strip and refinish a floor and clean the carpets in the same day. After awhile, it didn’t mater which arm you used.
You posting above ANYONES head is about as likely to happen as Mikey not bragging on himself.
AlienAgent
Joe Gingerich
This is one more reason to target commercial only, drop the wand, and casually walk behind a Cimex or OP for a few hours a week.
In the blink of an eye you’re a worn out old man and nobody will ever remember how those carpets that got ripped out and replaced back in 2032 were cleaned in 2025. You’re shoulders and elbows sure will though.
Awe Hank! It’s not a higher calling, it’s just a business. It’s about making as much money as you can, while you can.
-Buck Strickland
I didn’t actually have to #target commercial only. We actually started out waxing floors and then everything else just came our way.
As the word says, I’ll give it to you little by little.
Reactions: AlienAgent
Brian H
Brian H
Speaking of rotator cuffs, I have a full thickness tear of my supraspinatus tendon in my right shoulder. Total separation from the attachment point. As I can manage the pain the surgeon says I can wait until fall to have it repaired. I don't want to lose the entire summer with my arm in a sling, so I just have to tough it out.
Hoody
Steven Hoodlebrink
I write right-handed as well as throw/shoot a ball and bowl with my right. However, I bowled left-handed until I was 12 when I broke my arm and switched to right. But I play hockey, shoot pool, and power hit in baseball left-handed to this day. Back when I cleaned carpet/floors, I could easily switch from right to left because the motion was similar to handling a pool stick for me and I've played pool since about age 8. When we would do a lot of apartments I would alternate arms every 2 units or so.
I clean right handed but in hockey I shoot left handed.
Reactions: Hoody
icleancarpetz
Rafael Samson
Daily exercise, stretch the body head to toe
Work smarter not harder.
Slow down a moment or two when setting up and breaking back down
Slow in the van grabbing equipment
Slow coming out looking at every footing before taking the next
EAT HEALTHIER
Lastly, you are getting paid to exercise instead of giving your money to planet fitness.
Lastly lastly…. If aging…start now another easier trade or save all your money and invest wisely to retire somewhat easier.
EAT HEALTHIER
great advice!
Brian H
Brian H
And I finally had my surgery yeterday. Now 2 months in a sling with plenty of PT.
You'll get close to #littlebuddy!
Glad you're Done! That's what they call the sling where Diana had her surgery.
