The new Aerotech Slide In units
Lint Basket
Scott Mckay
The information is too small to read on my phone. Are the frame, tanks AND REELS stainless?
The frame and main brackets are stainless also the heat exchangers are stainless tube and shell like the XT and DDS. The heat shields are chemical treated brushed aluminum so you can touch them up with steel wool and keep them pretty. The vacuum reel is aluminum and the solution reels are stainless.
Even though we have our own paint shop we choose not to powder coat as that never lasts. The front panel is a bit of a dated look but it is growing on me. We are going to add some stainless bling to the grill and help finish out the look.
Reactions: hogjowl
Lint Basket
Scott Mckay
The recovery tanks are either stainless or rotomold plastic. Stainless is the only thing available currently. Fresh water tanks we have 110 gallons poly with the unistrut system or the 45 gallon saddle tank with unistrut and stainless shelving above .
Reactions: hogjowl
Are you free to discuss how Chem-Dry affected the origin and look of these units?
they live
Steve
Try the zoom feature.
Reactions: SamIam
Lint Basket
Scott Mckay
That’s a good question, I don’t know the answer to that but I’m curious as well. I’ll let you know the history on that.
  • Love
Wow, that thing already looks outdated. Does it come with a Members Only jacket?
Paint that thing blue, and you got an old hydra-cat or crossfire hydra master, lol
But on a serious note:
Yes it looks like it has easy access to change oil and maybe the belts
But keep in mind that's only a very small percentage of the type of maintenance and repair these machines need. I think it's going through some competition.
It looks like it's trying to compete both with steam-action's design of stainless steel and trying to give it the high tech design of sapphire truckmounts.
I can't get over the fact that it is not very easy to access every part of the machine from the pictures shown. If I'm wrong, bring one over to my city and let's take the thing apart to get the needed access to all the major points of the machine, put it back together and do a successful hour long test of the machine. I don't care if you want to show off the performance of how it cleans in a 3 bedroom apartment. Every truckount does a good job at that, even an EZ truckmount. Ease of access on the job and maintenance to get it back up again is the only important factor!
I keep every tool needed on my Truck to do all popular repairs on the job. Very few I have to leave and go pick up my spare machine. So meet me to the challenge and let's record it. I laugh at chemdry being the tester. Bring it to a real owner operator who takes this business seriously.
Chemdry doesn’t take business seriously?
Apparently not enough to continue with this truckmount.
They backed out of it and laid off Wayne Boone and Rick Aranda after a dozen or so were delivered. The problem isn't in the unit....
Rick is back at Jon Don and Wayne is full time with AT now.
Very similar story to the ZeroRez/ DDS units AT built for Jon Don
AT is smart to remove those fickle franchise middlemen and sell to us Owner Ops instead.
ChemDry is all about change these days.....
I was pretty certain they wouldn’t be associated with Jon-Don for very long.
I don’t really care how the unit looks. Damon’s a California kid and puts emphasis on appearance over function. If it’s functionality is utilitarian and it’s not a hassle to work on then I’m good.
I think you're ugly but I would still be seen with you in public.
Reactions: SamIam and hogjowl
Lint Basket
Scott Mckay
Does that PSI engine have a timing belt or timing chain?
To remove the panel there are bolts that hold the along the bottom and sides. Notice that the plumbing section of the panel will stay in place. Then you remove the bolts that hold the radiator in place then the radiator will swing out and away. Now you remove the bolts holding the cover of the timing belt. Wayne has tested the time it takes for this process and said it’s a two to three hour job. All accessible from the front.
The thing with PSI is that they are not the engine manufacturers. They take the engine blocks and build out the engines from there. This particular engine is a GM engine. The way Wayne explained it to me is that if the belts do fail it will not damage the valves the way this is designed.
2-3hr job is normal for a replacement. I like that they used a GM engine and the heat shield over the manifold has improved since my psi GM model engine was made.
I like that it's all accessible to the front since the basket filter and tank are on the right side. I was wondering how easy it was to remove that if it was needed access from that side.
Thanks for showing us up close access to it.
Is there any future talk about shifting over into Kubota with a timing chain for less of a need to open up that area of the engine once the first run of these machines is sold?
Reactions: SamIam
Lint Basket
Scott Mckay
There is a lot on everyone’s plates right now. The next thing we will be doing is revamping the DDS to bring some costs down out of it. The DDS is really done up with Stainless. Just the recovery tanks are a fortune to produce but they are awesome.
I personally would like a bigger blower model to compete with the bigger TM’s but that’s just the XT in me. People say you already have the XT if someone wants big so who knows.
The question is will Kubota step up their game and make a compliant engine? That would open the discussion.
I think the 56 blower is the perfect size. I’ve never used the giant blower in your big pto but my tm was dual wanding for 4 days at 2 really big churches at about 600 ft combined with no drop in suction.
I understand the need for the dds. It’s probably more friendly for an employee who works at a 50 truck franchise so there is a strong need. The word on the street said there was no problem in the engineering of it. The problem was the incorrect installation from the dealer who sold it.
I see that you guys are working hard on correcting that issue. Your machines are definitely on my radar 😊
LintBasket/Scott Mckay will be bringing a new Aerotech R56 unit out for he and I to clean the Ronald McDonald House @Stanford CA on May 31st.
Plenty of Carpet, Tile and Upholstery to take care of
I'll use the GreenGlides Chosen and Simple wands, the Multi Surface wand and the super cool and versatile BETA GreenGlides Upholstery tool
This is not a Mikey's Fest so we can't have onlookers standing around. After the cleaning we 'll probably have a get together where people interested in seeing this machine can stop by.
Look for a walk around and in action video
Dwain Ray
Could you use another machine and operator? I have family in Lafayette less than an hour from Stanford. I can have Frankenstein can be gassed up and there first thing that morning
Reactions: SamIam and Mikey P
View attachment 130836 View attachment 130837 View attachment 130838
I believe that would be called a non-interference engine.. Which would be an awesome thing..
They have enough vans for flooring. Do you have a portable and the desire to clean upholstery?
Reactions: SamIam
Dwain Ray
More than happy to help clean upholstery, but i don't own a working portable. I have a steamgeni 733 portable in pieces but it hasn't run since putting it in storage in 1983
Dwain Ray
Ya but then you would be left with less to comment on. So im doin Just a little extra for the cause
Reactions: SamIam
