What are these parts?
lesterj2
What are these parts:
lesterj2
Re: Quick Explanation if Possible
Mikey P said:
A -Waste tank
B-Water Box
C-Filter Box
D- Muffler
E-Silencer
ok thanks for the input... but if possible could you tell me the functions of each piece of equipment...
Be alot easier to just find a distributor near you,they should know the basics.
Kevin
Brian R
Little Elm, TX
Brian Robison
I commend you for just jumping right in with no experience what so ever with the truck mount.
With that said, Dude, You really need to take a class on this even if it is an informal one. This board will help I have no doubt but you reall need to know the basics.
I hope that you are not kidding but at the same time I hope that you are kidding. Most seems to be common sense.
WISE
Can't tell, but looking at the other pics, not sure if "B" is a water box or not.
WISE
lesterj2
SRI Cleaning said:
B is the blower heat exchanger
so what is the purpose of the heat exchanger...
im thinking its like a mounted water heater, correct me if im wrong... :?
SRI Cleaning
West Chester, PA
Anthony Firmani
Yes, there are 2 of them. They take heat and use it to heat the water. The one in the picture is on the outlet of the blower. As the blower is running it creates heat. the exchanger captures that heat and uses it to heat the water. There should be one on the other side of the machine. This one has the engines exhaust running throught it and it heats the water even more. The one in the picture hangs off the side of the machine, the other one should be right behind the motor and it probably has a bunch of sensors and wires coming out of the top of it.
lesterj2
here is a pic of the other one...
and its connected to the muffler in the bottom pic in the bottom right corner...
that sounded like a tongue twister... LOL
Wi
Have you cleaned your carpets yet? See how it works! That is the best way to figure it out. I never had any experience with truckmounts when i bought mine i just ran it and went from there. I bought new though so that eliminated alot of problems.
lesterj2
im completely lost... all i know how to do is crank the thing...
lesterj2
Mikey P said:
Lester
How do you know the machine produces hot water when you don't have a wand yet?
on the machine where it has the connection for a 2nd wand the valve is sticking... I didnt know so I took off the quick release cap to my pressure hose and it shot hot water on me & mechanic... LOL
wow.... so this unit was made as a production unit from a name brand manufacturer? I would swear it came out of TX.
Lester I was convinced you were a fake poster, this whole experience has been surreal. If you don't mind answering, where did you attend high school?
When you get that $139 wand, let us know what the Temperature gauge shows on the machine while you are pulling the trigger, just warm it up at maximum throttle for 2-3 mins. and pull the trigger for 60 seconds and report back. (I'm pretty sure that wand has 110 02 jets).
Lester would be the first phony poster to create a Pay Pal subscription.
He may not know shit about Truckmounts but he sure knows his way around a PC.
Brian R
Little Elm, TX
Brian Robison
Yay!
lesterj2
@ Greenie I attended High School in Albany, GA... just a regular High School with low funds... LOL
what do you think the temp is gonna overheat because of the wand or something..
i think this is a pic of the pump gauge in the bottom pic... correct me if im wrong...
Lester, your profile says you've been in biz for 5 years
what biz is that, pray tell?
and is it part time of full time biz?
.L.T.A.
lesterj2
.L.T.A.
i been cleaning carpets for 5 years... mostly family and friends...
Bob Foster
Lester, the circled area - that's your pressure adjustment for your solution line. Adjust it with the pump working and the trigger on.
lesterj2
so i should fill my 5 gal jug with straight water and adjust the cap while squeezing the trigger on the wand...
if so will it show the pressure on the gauge...
Bob Foster
Lester the solution line has to be hooked up to the wand and just shoot the wand on the ground. Make sure the water is hooked up and on or the water tank is full before you run the pressure line (trigger the wand).
lesterj2
gotcha... but before pulling trigger should i leave the valve adjuster where it is -or- close it all the way then open it back up slowly until i reach 300-400 psi...
Brian R
Little Elm, TX
Brian Robison
I would say close it just in case someone has it turned all the way on and you bust your valve on the wand.
Righty tighty, lefty loosey. :mrgreen:
or is it the opposite, crap, now I gotta go look.
lesterj2
yeah thats what i was thinking maybe the last job was tile/grout... dont you use a 1000-1200 psi for those jobs...
