What is causing the white spots on this slate?
boazcan
Bryan C
Sent from my DROID RAZR HD using Tapatalk 4
J Scott W
Jeffrey Scott Warrington
I would suspect moisture trapped under a finish or sealer. USe an air mover or a hair dryer blowing across the surface (not down into the stone) and see if this corrects the situation.
Reactions: John Olson
John Olson
John Olson
agree with scott slate is void of calcium so it isn't efflorescence nor is it etching from acid since it doesn't have calcium.
Efflorescence from the thinset below
Where are those tiles installed?
boazcan
Bryan C
Back patio of condo 2nd floor water side. :D
boazcan
Bryan C
I didn't take a closeup of the spot after, but here it is after dry treat enhancer.
You can barely see it left side near sliders about middle of the pic.
Go back in a month (or less) and take notice..
Like I guessed before, thinset minerals...
