What’s the best portable for me to get.
michael45
I want to get a 3 stage 300-400 psi portable machine. I understand that every one has a truck mount today. Eventually I will be getting one. What’s the best portable to get today in 2019.
Look for one with 2-3 stage vacuum and a 500 psi pump. 2 power cords. Some require at least one 20 amp circuit. Better to find one that uses 2-15 amp circuits. Don't worry about heat. There are no electric heaters that will keep up with the flow unless you have multiple power cords
Reactions: Hack Attack
michael45
Thanks I was looking into getting the new ninja machine at 500 psi 3 stage non heat. Would I be able to call you up and ask you some questions, if you don’t mind. I appreciate it.
Ill be out this evening but sure, I'm available after 5 PST usually. Make sure have 2 3 stage vacuum motors. There are a lot of ninja with just one. I would look for a machine that has 2 inch plumbing. One of my machines is a Mytee Speedster. Not a bad machine. I had to modify it for use in Canada. Look at one of those before looking at others for comparison.
DAT
Bill Cheryl
According to these old farts, you should ditch the porty chum bucket route and go work for Stanley steemer...
Has anyone mentioned you should get a fully loaded Butler instead yet?
those that don't frequent other boards might not see the humor
guy on the fishing board has a $70 to spend on a rod, and several YO-YOs suggest Sage, Scott or Loomis ($500 rods)
Guy has $400 for a gun...cueballs suggest a Wilson ($3000+)
guy with $500 wants a mini-bike for his kid ...some yokel will suggest a Honda Grom
Reactions: FB19087
hay did you see the rotovac 2 two stage vacs hooked up to 50 ft of 2 inch hose at Mikeysfest????
that thing had some suck.
you got one didn’t you?
It's very powerful. I would prefer to see the vac motors in parallel. As it is though, if you combined it with their ranger system with the 500 psi, or a 1200 psi pump for tiles, it would be a great system for portable use. Just have to be careful of foam coming out the exhaust.
